Naio's avatar
Naio
Explorer II
Jun 09, 2016
Road rash and rust, in the arid west?
My search for a new van continues. Yes, every used vehicle has SOMETHING wrong with it :).
The current candidate seems great -- but it has a LOT of road rash. I don't mind. It's a boondocking rig. But if I keep this van for 8-10 years, will I then have a problem?
The rash on the front has no rust, presumably because of the heat from the radiator. But on the sides, each tiny pock has a speck of rust in its center.
Would it be a good idea to treat with naval jelly, or something similar, and then with a paint kit like DR? Would I end up with broader areas of rust under the paint if I do not? Would I even if I do treat? Is there a better treatment?
Thanks, guys :).
  • Just know that rust doesn't sleep. Eventually, any rust spot will be a rust hole. I use Jasco prepaint conditioner at a 50/50 dilution rate on auto finishes. It tends to neutralize the rust and removes any oxidation in the paint.
    If you really don't care about cosmetic perfection, remove the rust and repaint.
  • Naio's avatar
    Naio
    Explorer II
    Yes, I am talking about chips.
    Of COURSE mechanical stuff is more important! It drives great, except for a steering issue, and is in the mechanic's shop right now for checkup and to diagnose steering.
    But the chips, so many of them, are a new thing to me so I want to ask you all if they are a bigger deal than I realise.
  • Are you just talking about rock chips in the paint? If so, and you don't care about the appearance, I wouldn't worry about it. We have two 20 year old vehicles in the family with plenty of rock chips. They remain unchanged as far as I can see.
  • How does it run, how does it shift
    Does it use oil, get hot, leak
    Mechanical problems can leave you stranded
    My priority is always mechanical first
    Body work paint etc.. any number of ways of treating that
    Rust on the rocker panel is not going to strand you someplace
  • Naio's avatar
    Naio
    Explorer II
    The road rash is because the van used to belong to a mining company. This was 9 years ago -- anything else I should look out for, with the many miles of gravel roads?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
