Bobbo's avatar
Bobbo
Explorer II
Oct 18, 2014
Rodent control attempt
I live next to a 1/2 mile square wooded field, and mice/rats have always been a problem in the yard and shed. However, our terrier mix loves them.
Yesterday, I noticed the dog crawling under the RV. She has never done that before. I looked under the RV and saw her trying to crawl into the engine compartment. I opened the hood and looked in there. There are leaves piled in there where no leaves could possibly blow. Uh oh. I raked out all the leaves I could and, leaving the hood open, put a drop cord with a 40 watt light bulb shining back there all night.
Today, I bought an 1156 socket and attached it to the end of a 3 foot long wooden dowel, so I can actually push it back into the compartment. I wired it through a 3 amp fuse to a pair of clamps so I can attach it to the battery terminals. I now have the hood open so the area is open rather than enclosed, and permanently lit. I hope that will discourage the little boogers.
I have the RV permanently plugged in and have a Trik-L-Start charging the battery the lamp is hooked to. I should have no problems with killing the battery.
I will post back if the dog loses interest in the underside of the RV.
  • Bobbo wrote:
    OP here, I live in Memphis, TN. The RV is under a carport so rain/snow is not an issue. The Trik-L-Start is 5 amps, and I put an 1141 bulb in the socket so it draws a little less current. I may look for an LED to replace the 1141 though.
    That geographic area has only three general types of rodents:
    Norway Rat
    Roof Rat
    House Mouse
    NO pack Rats.
    Lights will do no good, other than make you feel better.
  • I have 4 traps set in the engine compartment and I leave the hood open 1/4 way all the time. Yes, I do trap one every so often but so far no evidence of nesting activity. BTW we are on 5 acres of prime mouse habitat.
  • OP here, I live in Memphis, TN. The RV is under a carport so rain/snow is not an issue. The Trik-L-Start is 5 amps, and I put an 1141 bulb in the socket so it draws a little less current. I may look for an LED to replace the 1141 though.
  • tvman44 wrote:
    I have read that a bright white LED light discourages them, worth a try. Would draw less current and put out a lot less heat. :)
    It will discourage pack rats only.
    The OP does not disclose where he lives so species is hard to tell. Pack rats are mostly found in the western states.
    Most other rats and mice live with man and are not bothered by lights at all.
  • I have read that a bright white LED light discourages them, worth a try. Would draw less current and put out a lot less heat. :)
  • no light, thats heat and they love a cozy place for the winter, get some peppermint oil, and put drops every where. close up all holes a mouse can get thru a hole the size of a dime. get two more dogs. and a steak bone for the one you have.
  • An 1156 bulb will draw around 2 amps - hope your trickle start is a lot bigger than that.
  • I don't know what the winters are like where you live, but here in northern AR I would not leave the hood open because of the ice and rain storms. If you close the hood and leave the light on it will provide a warm place for the rodents and they will move right in. If you didn't have dogs, you could put out antifreeze and/or rat killer around the MH and that would help with your problem, however, dogs like these things as much as the rodents do and you will end up killing them also. I have heard that rodents do not like Irish Spring bar soap. The person who told me this shaves up several bars and puts the shavings around the tires of his stored vehicles several times a year and claims to not have a rodent problem.
  • The same thing happened to me some years ago. I cleaned up the stuff and what ever it was never came back. I never did do anything to discourage them.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
