mena661's avatar
mena661
Rogue MPT-2024 on the way
Mark posted some info about it on the Rogue Facebook page. Supposed to be $275. Here are some specs:
* Supports 12v and 24v battery banks
* 100v max Voc PV limit
* Very low standby power consumption
* Auto fault resolution (faults will not require the user to restart the controller)
* Reverse battery and input short protection (without using relays or blocking diodes)
* User-upgradable firmware (with optional data converter)
* Fully automatic startup
* Extensive data logging and real-time data accessible with the PC connection and software utility
* Historical data log accessible via PC
* Modified MPP tracking algorithm with new triggers for sweep and user-adjustable options
* LED display for battery voltage - can be turned on or off from front panel at the press of a button
* LED indicators for charging mode and fault status
* Adjustable battery temperature compensation
* Adjustable current limiting
* User-adjustable calibration
* DIP switch for selecting startup charging profile - profile and setpoints can be changed at any time with a remote display or computer interface
* Smaller footprint, lighter weight, robust thermal design (no fan)
* Conformal coated circuit board
* 18-ga steel enclosure with black textured powder coat finish
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
