Salvo wrote:
Never heard that gain error is greatest at full scale. Can you provide a link? Are you saying the gain error is nonlinear? The gain is probably set by a couple of resistors connected to the error amp. These resistors are not perfect. They have a tolerance that more or less defines the measurement gain error.
You're thinking of an op-amp, whereby gain is set is set via external resistors. Input bias current in that case certainly makes the response non-linear. With an ADC, the difference between offset error (measured with zero input) and gain error (measured at full scale) does normally cause a non-linear transfer function. I'll leave it up to you if you want to find a link for it.
The whole object of the amp & volt measurement specification is to determine what's the possible error when reading let's say 5.0A. Are you saying it's impossible to determine this error without measuring it? What's the purpose of your spec? What's does 1% at 100A mean? Max current is only 30A.
I'm guessing your current measurement error is at best 3 to 10% of reading plus +/- 0.1A. 0.1A is LSD, not offset.
Sal
No, the purpose (at least in my case) was to give a maximum figure, which is greatest at full-scale. The current sensors are good to 100a, so that's why 100a was chosen as the full scale figure.
0.1A would be the resolution. The LSD, by definition, could be any number from 0-9.
Sal, if you have any genuine critiques or questions, I'd be happy to entertain them. Nitpicking about non-issues doesn't qualify.
