I bought a double nice 87 Fleetwood Bounder.Only 29k on it.I don't know nuttin about these types of units.The front one works perfect.The rear unit blows air but not cold. Before I start on it....I...
When you say one works and not the other is that with both turned on at the same time or independently?
You probably have a 30amp service that will only run one at a time. The units go into what is called shedding, basically one compressor turns on the shuts off, then other one turns on.
First check the unit that is not working by itself. If still not cold, remove the shroud on the roof and give it a good cleaning. That would be where I would start...
Good luck
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
