acker1's avatar
acker1
Roof air questions--now need motor info 5/6/14
Dometic 13,500. When I turn the AC on or only the fan on the coach, the breaker for the AC trips. Changed the breaker (20amp) and still the same. Cannot find anything wrong with any wiring. Fan is turning easy. Pulled the capacitors and did a check (test) I found online. They didn't check right--not sure if it's me checking or actually the capacitor.
Will a bad capacitor trip a breaker? If not, where else should I check?
Thanks
DICK
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
