Eagle670ExplorerJul 13, 2016roof constructionI have Zepplin 271 keystone with a water leak. I think it may be coming from the roof. How is the rubber roof constructed? Does it wrap around on the sides or just stops the trim. Thanks
gboppExplorerJul 13, 2016The rubber roof is glued to a plywood base. The rubber usually stops at the trim, it doesn't go down the side of the RV.If you can't find the leak, try a Pressure Test.Use Eternabond for the seams and anywhere else you can use it on the roof.Dicor Self leveling Lap Sealant can be used on horizontal surfaces.They're both great products.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentBounder ConstructionOverhang construction'15 Coachmen Class C Roof Construction (layer diagrams)?Roof constructionArctic Fox front roof seam construction
