- shepstoneExplorerJust as a point of interest, the newer Open Range use PVC on the roofs. Pros? Cons?
- hammer21661ExplorerThanks everyone, I'm going to check out the spray on stuff but will probably lay some glass. Unfortunately. Lol. I'll take some pictures no matter what way I go.
- fourthclassCExplorerRubber roof replaced with fiberglass then painted. As done by the Famous Tioga George (he is still rv'ing it ) He had it done on his rig in Mexico by a small boat building outfit in . It came out great from my point of view. Rubber roofs on RV's are the thickness of a bicycle tube. It might have a chance of lasting if it was a comercial grade PVC/rubber roof but they're not. In my opinion fiberglass is the best material for RV roofs. If you remove your roof, I bet you will find the aluminum edge trim puncturing it in several places. Meaning it was leaking there from day 1 installation at the factory.
- jplante4Explorer IIHammer - I think once you get in there you'll discover that the wood around the AC penetrations have been wicking up water and rotted. This is the most likely reason for the sag around the unit. Cut back to good wood and patch before you recoat. We had a bus in the shop last week with the same problem. And you're right; left unfixed and you'll end up with the A/C inside the trailer. It may be on the next bump.
- TakingThe5thExplorerI’ve heard people talk about something called Bus Kote. I have no personal experience with this product but thought it would be helpful to mention it -
Bus Kote - theoldwizard1Explorer II
hammer21661 wrote:
Has anyone ripped off the rubber roof and fiberglassed it like a boat? Or maybe I should use aluminum. Like 8x20 sheets so there is only an edge seam and one in the middle? Any thoughts?
Fiberglass is definitely a DIY job. Not easy, but doable.
Likely it will take 2 or even 3 sheets of 'glass (NOT chop strand or roving).
Yes, it will add weight, but not really that much. There are lots of YouTube videos about boat people replacing a deck/floor. The biggest downside to fiberglass is that it does have to be painted to prevent UV damage.
Aluminum would be better, but it is difficult to source in large sheets and probably requires more work to install. If you go this way, you need stainless steel screws with rubber washer. Use butyl tape under/around all seems. a properly installed aluminum roof will last a long, LONG time !
Remember most leaks occur around seems/joint. Roof protrusion need proper flashing and caulking. I would replace the side molding with RainKap
Read this !
Replace all screws with stainless steel. - JIMNLINExplorer IIIIf you decide to go with aluminum don't use sheets up there. Use a one piece seamless to cover the roof in one shot. Also I would recommend white as those old mill finnish aluminum roofs on our older rv's were hot in the summer. Aluminum roofs are noiser in a downpour.
The more lap joints/holes and screws up there only increases the chance for more maintenance and better chance for water intrusion (leaks). - memtbExplorerhammer21661, “IF , you have a fairly expensive rv and plan on keeping it a long time.... this may be something to check out. This method is expensive, but IMO worth it, if you meet the opening disclosure. FlexArmor!! The application requires everything be removed from roof, any roof repairs completed, all mounting hardware ( for ac’s, satellite systems, vents,etc.) put back on roof, then the material is sprayed on. Once done there are “no” seams/joints, and “no” perforations through the roof. It carries a “lifetime” warranty. There are videos on YouTube showing how it is done, the strength of the material, and actual application process. If nothing else...the video is informative. Technology is evolving almost daily on many things...RV roofing is also evolving.
fj12ryder wrote:
There have been several people who have replaced their rubber roof with a different material. It tends to run several thousand dollars, so it just depends on how badly you want a different roof.
If I don't I'll be making payments on something that's in the junkyard or the A/C is going to fall on me and kill me. - hammer21661Explorer
edatlanta wrote:
I replaced my 5 year old failed membrane rubber roof with This 2 years ago. If you search for my posts in early 2016 you should find lots of info.
I will never ever have another rubber roof longer than it takes to have it sprayed. And don't believe the 10-12 rubber roof warranty. I was offered $225.00 total compensation under my "warranty".
PM me for more details, but look at my posts first. 2 years later I'm sitting here right now under hard rain and not a single caulking joint or the rubber to leak.
I've been thinking about this too but I know how to lay glass and I know it'll be right when I finish. If it isn't right I only have myself to blame.
