pianotuna's avatar
pianotuna
Nomad III
Mar 28, 2016
roof rack for solar
Since I'm committed to 12 volt because of a pure sine wave inverter, if I upgrade I will go MPPT with the Magnum PT-100. That would allow me to install 1200 watts of solar. To do that would require a roof rack that goes above the air conditioner.
How much clearance would I need above the air conditioner shroud? I will have a way to remove the panel(s) that cover the conditioner.
How would you secure the rack to the roof?
The RV in question is a 28'5" class C.
  • Hi Cee,
    If you are planing to replace the inverter then I'd strongly urge you to consider a 48 volt battery bank. If I were starting from scratch, I would certainly not do 12 volt.
    I'd also consider a Victron hybrid. They don't seem to have the issue with GFCI outlets that my Magnum has. I.E. it appears to not be loved by some gfci--but others it works just fine with. It is not a fault in the RV, for if I wire around the Magnum, the gfci does not trip.
    BoonHauler wrote:
    Cee
    PS: I'm looking (in the not too distant future) to change out my MS inverter for an MSH. You and I have a lot in common although I'll stay away from the resistance heating.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
