pianotuna's avatar
pianotuna
Nomad III
Mar 28, 2016
roof rack for solar
Since I'm committed to 12 volt because of a pure sine wave inverter, if I upgrade I will go MPPT with the Magnum PT-100. That would allow me to install 1200 watts of solar. To do that would require a roof rack that goes above the air conditioner.
How much clearance would I need above the air conditioner shroud? I will have a way to remove the panel(s) that cover the conditioner.
How would you secure the rack to the roof?
The RV in question is a 28'5" class C.
    That is a lot of solar, what are you using for a battery bank?
    I don't know how tall your RV is but I would keep the panels less than 13' off the ground or 3" - 4" above the AC.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
