Marknfld's avatar
Marknfld
Rotted floor joist
Hi I'm mark and I'm new to this site and owning a travel trailer in general. To make a long story short I just purchased a used 2006 27' springdale with a slide. I took everyone's advise when buying a camper and looked for sighs of water damage and other important things which I did not find. Well I've had it for a month now and I did fine a soft spot in the front storage compartment that goes back into the front room. The soft spot is about 1'x3'. When I started to cut that out I seen that someone had already done work on the floor but the thing that really scared me was that it seems like when the previous work was done they did not repair the floor joist that run tge length of the trailer that the main wall sits on. Now the main floor joists are completely rotted and I have no idea wt to do to fix it. This is the first tt I have ever owned and now I think I'm in over my head and feeling really overwhelmed. Any advise, tips or even similar stories would be greatly appreciated .
Thanks mark
Moved to Tech Issues forum from DIY.
  • The best way to post pictures is to upload to a free service like photobucket that makes it easy to get an IMG link to the photo. Then just paste the link in your post.
  • I'm not quite sure on how to post pics, I'm new to these types of forums
  • Hi Mark, this is how I have handled the problem. Sorry but I do not have any pictures. Joist do run the length of the trailer, but joist below wall are supported by metal "out rigger braces" every so often. You just have to cut back to good wood before brace, where you can do a splice.
    Whenever I have had to replace bad flooring in a RV trailer, I work from the top down. The membrane on the bottom of the trailer is usually a fiberglass reinforced waterproof material. Once you take up flooring you will probably see several joist that need to be replaced too. On one of my trailers I replaced about 20 SQ feet of floor and joist in the back corner under the tub, and on my neighbors trailer we replaced about 50 SQ feet of floor and joist in the front bedroom due to leaking storage doors. Here is how is was done: On one rain water came in at a damaged refrigerator vent and ran back under the tub in the adjacent bathroom. On the other storage doors for an under bed storage area leaked. You will need to take out any cabinets or items in the area of the damage. I ended up replacing floor joist, and some wall studs too. There are two kinds of wall construction, on some trailers the wall extends past the floor platform which makes removing damaged floor easier. On others the wall sets on the floor plate, and the wood flooring has to be removed from under the wall, then to reinstall you need to jack up roof enough to lift wall so that you can get new floor material under the wall. To remove damaged flooring I used "skill" saw set for about 3/4" deep to get back to good material. To remove damaged joist I used a "triangular shape blade" for my saber saw that lets you cut flush to another surface. If I was working up to a material that could be damaged, I placed a small piece of aluminum sheet below item to cut so as not do damage adjacent surface at end of cut. Also used a "Drummel" rotary tool in some tight places. Used deck screws to install new joist. Predrilled member to attach, so it would pull up tight to exist joist. Used screws to install flooring too. If you need more information send me a PM.
  • If you can post some photos we can advise you a little more....
  • Hey Mark,
    You'll probably have to pull up some flooring and replace the rotten joists. Take it slow and it won't be overwhelming. If you don't have the required skills to do it, enlist a friend with some carpentry knowledge. These RV's are not that special that they can't be repaired. I pulled all of my flooring sheet goods out and replaced it. In the course of that, I replaced or added joists.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
