ajriding
May 20, 2019Explorer II
Considering all the possible options on mine I ended up just snipping the bug screen and ran wires through the top opening of refridge vent. Easiest and with no new holes comes no new leaks…
Route wires from the back side if you do this so rain water when driving will not run up the wire and into the compartment.
Also, this method is very un-doable if you remove the solar system.
Whatever you do make the most direct path to the batteries (controller too) that you can. DC power likes short wires of big gauge.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
