f150camper
May 20, 2019Explorer
Maybe I should go with one 250W panel?
Not sure I understand why a MPPT controller has no advantage over PWM for two or three 12V panels. If wired in series, that's 24V or 36V as well, especially if you don't want to use the bigger wires.
Are the Renogy MPPT controllers any good? Are there others that are significantly better?
Also wondering if the CC is getting hot enough to make a difference to the temp inside the camper when mounted inside.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
