Joe417
Jul 25, 2019Explorer
I wouldn't put the Eternabond on first and then put the strip on top. You would be putting holes in the backing of the tape.
If I wanted to put it back the way it was, I would put Dicor across the joint temporarily. If you aren't pulling it around it will keep the water out until there was time to get the Butyl tape and re-seal it like it came from the factory. One tube should seal the rubber to the front cap temporarily.
I would call putting a bead of the Dicor across it, bedding the termination strip in it and screwing it down and then covering it with the eternabond tape a permanent fix. If you clean it "real good" where the eternabond can stick to both the front cap and the rubber it wont leak. You said you have 40 ft. of tape which should be enough to make overlapping runs across the termination joint.
As long as it is real clean it will seal it.
