NanHenson
Jul 26, 2019Explorer
Joe417 wrote:
I wouldn't put the Eternabond on first and then put the strip on top. You would be putting holes in the backing of the tape.
If I wanted to put it back the way it was, I would put Dicor across the joint temporarily. If you aren't pulling it around it will keep the water out until there was time to get the Butyl tape and re-seal it like it came from the factory. One tube should seal the rubber to the front cap temporarily.
I would call putting a bead of the Dicor across it, bedding the termination strip in it and screwing it down and then covering it with the eternabond tape a permanent fix. If you clean it "real good" where the eternabond can stick to both the front cap and the rubber it wont leak. You said you have 40 ft. of tape which should be enough to make overlapping runs across the termination joint.
As long as it is real clean it will seal it.
I don't want a quick fix ora temporary solution. I am going for a permanent repair with the supplies I have on hand, because I will have to move. I don't have butyl tape, so I was mainly looking for a substitute there. Since Eternabond seals around screws drilled through it, I didn't think it would be a problem to do that. Basically, instead of having butyl tape, I would have Eternabond. I wasn't wild about the bed of caulk/overlap tape idea because I'm not sure there is enough caulk to make a good bed and if I taped over the termination bar, I would prefer it to be with the 4 inch tape, not the 2. Which is when I thought of reversing the layers. I have plenty of tape to tape down the edge, and enough sealant for the edges and screws of the termination bar.
