NanHenson's avatar
NanHenson
Rubber roof repair with limited supplies
I had to make a repair to the rubber on the roof which involved removing the front termination bar. I have one tube of dicor self leveling sealant and about 40 feet of 2" wide Eternabond tape. I have no butyl tape and no way to get any before the next rainfall. Is there a reason I couldn't/shouldn't use the eternabond to tape the metal edge of the front to the rubber roof, then put the termination bar over that?
  • You indicate trying to be economical in roof repair/maintenance...have 2 inch tape but not 4 inch tape. Not wise IMO.
  • Normally you use 4 inch Eternabond over the whole thing between the roof and the cap. For a quick fix using what you have, you can put the "termination bar" back on and put your 2 inch Eternabond along it with 1 inch overlap, so with 40 feet and 8 ft to do, you could do two 8 ft, with one overlap making 3 inches. Or even three and get 4 inches.
    It is hard to do all 8 ft with one length --it gets twisted up in the wind and turns into a nightmare, so shorter lengths overlapping end to end is more practical. Your 40 ft leaves enough for overlapping the end to end and for the lengths.
    You might not need the Dicor at all. Purists put Dicor along the edges of the Eternabond, but how long is this for, before you get some 4 inch and do it over top of this one?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
