pianotuna
Dec 20, 2013Nomad III
Hi DiskDoctr,
My lines of attack have been:
add insulation where ever possible
remove and block off areas such as the outdoor shower
use vent and skylight cushions
use oil filled heaters in multiple but out of the way locations
use radiant heaters
use a window fan thermostatically controlled replacing the return air vent on the furnace
use a thermostatically controlled heater in the waste tank area
use a thermocube tc-3 operating a 60 watt bulb in the fridge access hatch
install 34 square yards of insulbright covers for windows, doors, and isolate the cab area. (this reduced delta t from about 145 watts to 76 watts per degree above the ambient).
Basically, only the carpet covered floors in the bedroom, the floor in the commode, and the side entrance will not be heated. The entire aisle from the cab to the bedroom and the dinette floor will be covered by the Magic Carpets. They will draw around 1000 watts and produce about 3000 btu's. They cover a little over 30 square feet in total. That, at a guess, is about 75% of the entire floor area.
Stratification doesn't seem to be an issue. In fact I was able to warm the rv up when it was cold soaked at -31 c (-24 f) ambient, using only electric heat. It took three hours to get from -20 c (-4 f) to +5 c (41 f). I was running between 4500 and 5500 watts of electric heat.
I use a 12 volt electric blanket as a mattress pad.
Thanks for the offer of the chicken soup--it is a favorite of mine.
I refuse to use non vented combustion heaters. My daughter is a CO survivor.
Humidity was hovering at 25%. I'm reluctant to increase that as there are areas where the temperature may be below the dew point.
use radiant heaters
DiskDoctr wrote:
You are dealing with some serious temperature challenges! It requires multiple avenues of attack to make things more comfortable for you.
I don't think the heated floor mat will heat much of the floor. I expect it will provide a smaller respite from the cold on wanting feet, though :)
I would recommend "Red Head" synthetic socks from Bass Pro. They have free shipping now, though I doubt to Canada, so you may want to check that first. Lifetime guarantee, about $10/pair. I just ordered a bunch of them for my family and as gifts. Hint: Order one size too large. They are not constrictive on the calf as many are and are very thick, soft, and warm.
A tip that may help with the stratification of heat in a camper is to use a small, low velocity fan and point it from about table level to the ceiling (we use a bit of an angle to help in circulation).
You'll lose the hot spots, but gain in overall comfort.
If you were closer, I'd bring over a hot thermos of coffee or chicken noodle soup!
We do use a twin electric blanket (twin size are inexpensive and are the ones they advertise as special prices) as a throw blanket for DW, DD and I on the sofa while we watch a movie or play a game in cold weather. It helps some.
Our Wave-6 does a nice job of adding comfort heat (radiant warms these aching bones).
How is your humidity? Too high or too low makes your body feel colder.
Hot stew in the crock pot all day helps. Spicy foods help with the cold 'feeling' Actually, the flushing it causes can cool your body's core faster, but it feels warmer. Just be sure you are not in danger of hypothermia!
Foods such as a piece of sugar candy can temporarly help raise your core temp. Butterscotch is excellent!
Keeping hydrated (warm fluids are best) can be a challenge in the cold.
Hopefully some of these warm thoughts can help with your challenge!
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
