BFL13
Jun 21, 2015Explorer II
Revisit my 60 cell 24v results. 60 cell 24 is not the same as two 12s in series which is a 72 so at some point the 60 will lose "overhead" Then it is a question whether by that point you care, ie can the rest finish the job before dark or not.
Comparison of what? You can see what each controller is doing for its output amps. Both will be at the same battery voltage at output.
If you want to swap arrays/controllers it gets complicated for quick-connects etc.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
