jrnymn7
Jun 21, 2015Explorer
BFL said,
"Comparison of what? You can see what each controller is doing for its output amps. Both will be at the same battery voltage at output."
That's essentially my concern... would either controller operate at a different voltage, if on it's own? Indeed, they would combine amps, and match volts, but would it take the same voltage to maintain the pwm's amps to bank, as it would to maintain the mppt's amps to bank, if operating individually? I'm thinking, no, it would not. So I suspect that would skew the data, especially with two such mismatched systems, (either 500w or 250w mppt vs 280w pwm). And yes, I could pro-rate the numbers to compare, but it's the original numbers I'm concerned about.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
