KD4UPL
Dec 18, 2013Explorer II
The wind turbine is so not even worth considering I don't know how to begin explaining it.
I think you will want a larger than stock alternator. If yours has enough capacity left over after the loads of the chassis are met it will be working very hard and have a short life. Larger aftermarket alternators are available.
I'm doubtful that your 1000 watt inverter will start the AC unit. Have you tried that to see if it will? I suspect the starting surge will be too much.
You're idea will work if you get all the right parts; I would suggest:
150 amp or larger alternator, 2000 watt inverter, the largest marine starting/deep cycle battery that will fit in your battery location.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
