joebedford
Jun 28, 2017Nomad III
rockhillmanor wrote:Maybe it will work and maybe it won't. Personally, I wouldn't run an air conditioner off a 15A circuit. At my house, it doesn't work. We stayed at a fairgrounds once and ran air all day off a 20A. Not worth the risk of damage to me.
You stated that you only want to plug in at home to unload and load up the RV? You do NOT have to hand make an extension cord plug set up.
All you need to do is buy a 30 amp to 15 amp adapter plug.
Plug it into your RV power cord and than into the extension cord.
And then just plug extension cord into any outlet on the outside of your house and/or garage. That will run your a/c while you are unloading.
I had my MH hooked up that way for years when it was parked at home.
And used it many times at CG's! :C
