mtnman1000's avatar
mtnman1000
Running AC from Generator 150 feet away
I have a TT with a 13,500 BTU Dometic AC and am struggling with finding a good way to power it. My off grid property has an Onan 5.5 KW propane generator for use when the solar system needs charged or additional power is needed. I tried to use a a 100' 10/3 extension cord plugged in before the transfer switch that feeds the house and nothing is drawing power in the house. This resulted in 115 volts when the AC compressor is not on but once it turns on it goes down to 99 volts after a couple of minutes making the fan run slower so I cut it off. There is a bit of additional solid copper from the generator to the outlet I am using of about 30' plus the 30 amp RV plug which is 25' if I remember right.
My question is, is the voltage drop due to not a heavy enough gauge extension cord? If so, I can run some romex under the grass and install an outlet near the camper so what gauge would be recommended. My power draw is 11 amps when the AC is running plus another 2 for misc items.
Thanks in advance.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
