- ChooChooMan74ExplorerNo problems running converter, fridge, and 1 high amperage appliance on 20amps, as long as you have the proper adapters and cords.
- the_bear_IIExplorer20 Amp will work if the run to the panel is short and no other high draw appliances are running on the same circuit.
I have heard of folks melting plugs when they used an extension cord to get power to their RV from a garage outlet. Make sure you only use the trailer power cord or a short heavy duty extension cord to reach the outlet.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
