- dbontherunExplorer
pianotuna wrote:
Hi,
Yes, but it would be best to upgrade the charging path from the alternator. Otherwise you may arrive with low batteries.
The duty cycle for the fridge is around 2:3 (40 minutes on every hour).
What do you need to do to upgrade the charging path from the alternator? - pianotunaNomad IIIHi,
The duty cycle for the fridge is around 2:3 (40 minutes on every hour). - dbontherunExplorerI should be able to use the two batteries in the RV, right?
- 2oldmanExplorer IIyes. 350
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
