- ScottGNomad
mchero wrote:
Coke and Pepsi machines do NOT have heaters in them. Been maintaining these machines for the last two years.
Maybe the ones you worked on didn't but a quick Google search revealed that many do. - wa8yxmExplorer IIIAnother low ambieent temp trick.. Some models havew a LAT switch. what does it do?
Well if you were to insert a photo cell and measure it you'd find that the light does NOT TURN OFF. the small light adds heat to the fridge causing it to run and kwep the freezer..froze. - MDKMDKExplorerAdd refrigeration in different climates to the list of topics that draw the most in terms of conflicting expert opinions. Batteries and charging and solar are already on it.:C
- mcheroExplorerCoke and Pepsi machines do NOT have heaters in them. Been maintaining these machines for the last two years.
We full time in our rig. Norcold 4 door worked w/o issues even when temps well below freezing this6 last winter.
I restrict the vents on the outside cover during winter.
Previous poster mentioned the mess exploding cans create, that's nothing compared to a ice cream freezer loosing power, ice cream melting all over the inside then power is restored freezing the melted mess.
Time to break out the steam cleaner! - pianotunaNomad IIIIn weather cold enough the working fluid may gel. If it does it may cause a blockage. If you are lucky the blockage may be "jarred" free. If not, you get to replace the fridge.
- ScottGNomad
DutchmenSport wrote:
We kept all our previous TT's with ammonia absorption RV gas-electric refrigerators running 24x7x365, on both gas and electric (depending).
What we found out, after doing this for almost 20 years, is when the ambient temperature around the refrigerator gets colder and colder, the refrigerator has to run less and less. When the outside temperature get's colder than the inside, there is a point when the refrigerator will not run at all. Why should it? The inside is already cold, below the set temperature.
Now this worked ok, except for when the ambient temperature got around to 38 to 28 degrees. It at that stage the refrigerator doesn't need to run, to make things colder. It's already cold.
The problem is ... the freezer! The ambient temperature is still above freezing slightly, but the refrigerator is now colder than the setting. Result: the freezer doesn't run. So if you have nothing in the freezer, no problem at all. But if you anything that you don't want melting ... like ice cream ... well, the freezer is now not running either, but still not cold enough to retain things in a frozen state.
Once the inside of the freezer reaches 32 degrees or less, then things will start staying frozen again.
So, it will be fine if you have nothing in the freezer. Otherwise, you have to leave some heat on in the camper so the refrigerator warms up enough to run.
Now, what about household refrigerators and what about Coca-Cola vending machines? What keeps them from freezing in the dead of winter sitting outside? They actually have heaters built in them that will keep things from freezing when the ambient temperature drops below freezing.
This is dead-on correct and well written although I had not heard about resi units having heaters. - rexmitchellExplorer
Lesson learned when 12 cans of Coca Cola exploded in our refrigerator one winter when the temperature inside the trailer was negative 15 degrees and the outside temperature was negative 20 degrees. It didn't take much time for that cold to penetrate to the inside of the refrigerator.
The mess took about 3 hours to clean up once I found it! Lesson learned, when winterizing ... make sure EVERYTHING that has liquid is removed from the camper! Refrigerator included, even if it's left "on".
I had the same thing happen except in a car in the Texas summer heat. Black Volvo with white cream interior. 12 pack of cokes exploded. I wanted to sell that car after looking at the headliner. - MDKMDKExplorer
What about RV antifreeze?
Engine oil?
Bottled water? (it could freeze, but clean up is a breeze :B) - DutchmenSportExplorerLesson learned when 12 cans of Coca Cola exploded in our refrigerator one winter when the temperature inside the trailer was negative 15 degrees and the outside temperature was negative 20 degrees. It didn't take much time for that cold to penetrate to the inside of the refrigerator.
The mess took about 3 hours to clean up once I found it! Lesson learned, when winterizing ... make sure EVERYTHING that has liquid is removed from the camper! Refrigerator included, even if it's left "on". - notevenExplorer IIII’ve run RV fridges at -30F. But that was in Canada where it’s a dry cold. :)
Having RV issues? Connect with others who have been in your shoes.24,301 PostsLatest Activity: Aug 15, 2025
