sharp3's avatar
sharp3
Running generator on Natural Gas
I need some advise from some one who knows about LPG/NG conversions.
A while ago I bought a small 1.2 KVA gasoline generator and had it converted to run on LPG/Natural Gas by a mechanic. He drilled a hole in the carburetor midway between the existing gasoline inlet and carburetor's filter end (where choke is located), inserted and sealed a small metallic tube in the hole and then connected it to a demand regulator. This way he said that i will be able to run it on both gasoline and NG/LPG. He also gave it a test run in the workshop on LPG and it started and ran fine for a while.
After that i brought it home and tried to ran it on Natural Gas but it never starts (runs fine on gasoline though). They only thing i can do is start it on gasoline, turn off the gasoline knob and then when it start to die, turn on the gas. This way it continues to run on NG but keeps hunting and surging. With trial and error i figured out that when i move the choke almost halfway it stabilizes. Still, it only runs under very light load (say 10-20%). As soon as i increase the load further it dies.
My concerns are following:
1- Is there something wrong with the Demand Regulator?
2- Is there something wrong with the conversion mechanic did?
3- Are there any adjustments on the generator or carb that needs to be fine tuned?
4- Any other problem.
Is there any way i can run it smoothly on NG? I hope some one could help me out with this issue.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
