GordonThree
Jun 21, 2016Explorer
Tarheel Traveler wrote:
Hi all, haven't been here for a while, but know one of you can answer my question. Just acquired a 20' tag along with a fridge that only works with 115/120 volts. So, will it hurt the tv or the tag along if I run my generator(Honda EU2000i)while I am towing? Searched but couldn't find any related. Thanx in advance for any help.
Absolutely possible! It's not a big pain as some others seem to think it is.
Here's what I did:
1. From Lowes (HomeD, etc) I bought a 12 gauge (<- that's important) 50 foot outdoor extension cord, and a female twist-lock connector that mates with the male twist-lock on my RV. I also bought a few rolls of the plastic wire-loom stuff that's split down the side. Spend the extra $$$ on a true 12 gauge cord, they cost double what a regular "heavy duty" 14 gauge cord does, but that extra wire weight is worth it.
2. Cut the female end off the extension cord, and fed about 25 feet of cord through the wire-loom stuff. I saved 10 feet of cord on the female end, and made up a short extension cord with it.
3. Crawling under the trailer, I routed the wire-loom inside the box section of my trailer frame, and along the A-frame up to the tongue jack. The other end of the cable, I pulled enough slack to reach to where the twist-lock connector is.
4. Stripped and attached the twist-lock female onto the end of the cord.
5. Bundled up the slack cord at the front of the trailer and attached it with a bungie-cord to the propane tank.
Total time invested: 20 minutes if that, most of it was feeding the cord into the wire-loom stuff.
Any time I want to recharge my batteries after dry camping, or run the fridge on AC when I'm low on propane, I just unbundle the cord, plug it into the generator in the truck bed and let 'er rip.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
