phemens's avatar
phemens
Running Norcold off solar & inverter
I'm leaving our trailer at a non-electrical site until (Canadian) Thanksgiving, and I am giving some thought to the idea of running our Norcold N611 fridge off an inverter and batteries. The site has good sun for our 300 watts of solar, and I have 4x T-125's as battery bank. According to the sticker in the fridge door, the fridge consumes 2.5 A at 120v for 300 watts - is this continuous or peak?
This would avoid me worrying about running out of LP (has happened before). If this worked out well, I'd consider making this a permanent solution.
Anyone done the same thing or have any words of wisdom on the topic?
  • Almot's avatar
    Almot
    Explorer III
    300w solar will collect 110AH daily at best, with MPPT and all.
    300W fridge will draw 170AH daily at 30% cycle, and more with longer cycle. Forget about it.
    As others said, you should better increase the propane storage. If this is a seasonal site, install a permanent tank on the ground, or at least a couple of 100 lb tanks that could be replaced/refilled once every 5-7 weeks.
    If you want electrical fridge on non-electrical site - meaning there is no generator daily or every other day - you need either a 12V compressor fridge or VERY energy efficient 120V compressor fridge and twice more solar. Not a 2-way LP fridge. One 300W panel would feed the fridge and another one - your other needs. With a smaller volume compressor fridge, say 5-7 cu.ft, you could go with 400-500W total solar, but then it's a smaller fridge.
  • The 300 watts is continuous- it is a heating element, though the duty cycle is not 100%. You would be far better off increasing your LP storage, as I do not believe the solar setup would keep up.
    Continuous.. it's either 0 or 300w. Of course, how much time it's actually on will depend on the ambient temperature.
    This is going to be a close call. Your 300w of solar won't really be 300w.. more like 240w, and even then only for a few hours/day. And on cloudy days, forget it.
    I think if I were you'd I'd test it for a few days and see how it goes. My guess is that it won't make it much past a couple weeks.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 19, 2025
