vermilye
Apr 30, 2013Explorer II
While your converter is large enough that it will probably be able to keep up with the inverter draw, why add the wear & tear on the electronics of each, as well as the batteries?
The transfer switch that Prowatt supplies is there so that you don't need to use the inverter when on shore power. The 'flitch" you describe is just the very short delay that takes place while the switch it making the transfer.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
