dave17352
Apr 30, 2013Explorer II
3 tons wrote:wow I am going to have to disagree with you. As I said the refer draws about 360 watts on start up and a 100 watts while running. my inverter is rated for a surge of 3000 watts I don't see a problem.
Personally, I would not attempt to run a compressor type refer using a ProWatt 2000 (actually rated at 1800w continuous) since this inverter is not robust enough for this type of load. The ProWatt 2000 is intended more for electronics needs.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
