starremi's avatar
starremi
Running rubber LP tubing directly to regulator in RV oven?
Hello All,
I recently bought a little Wedgewood 4 burner range/oven from an RV. I want to use this in the shop on a 20lb propane tank. I know I need a 2 stage regulator, but my question is: How should I connect the bottom of the outlet of the regulator to the inlet of the oven?
From looking at it, the inlet is under the burner cover. I don't know what size it is yet (does anyone? I'm guessing 3/8), but from looking at YouTube it seems like this would have originally been connected to the copper tubing in the RV it came from.
My question is:
- Is it safe to slip a piece of LP hose under the range cover and run it directly to the stove inlet so that I have one piece tube between the regulator and the stove,
OR
- do I need to make a piece of 3/8 copper tubing w/ flare connectors to the oven, and then get that close to the propane regulator. THen use a rubber tube between regulator and copper. This would be more like the usual setup in an RV.
Thoughts?
  • Nope! No rubber in or near burner box ! Copper or black pipe at least 3 ft from oven is my recommend. Then rubber hose t grade for propane and a regulator for low pressure delivery.
  • Per Atwood (Wedgewood)
    • Gas line material inside the burner box must be rated for a minimum of 300°F operation
  • That is my initial thought but it seems like the boat forums all use rubber! I can't quite figure that part out.
  • I would be uncomfortable with rubber hose being that close to the heat. I'd use the copper tubing to where it is well away from burners and oven.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
