MEXICOWANDERER
Oct 07, 2017Explorer
"Damned knee kept getting greased. Damned ball kept getting wiped"
Stainless steel is a weak sister compared to "steel" the issue with them is not breakage, it's with the damned exposed threads beneath it. If you go stainless, do yourself a favor and hunt down enough extra nuts to cover all the threads (even if the nut is too thick and sticks below the threads). That way the stud can take a pretty good whack and not destroy the threads. You do NOT want to learn what it takes to remove a stainless hitch ball that has damaged threads. The damaged thread syndrome of course also applies to plain steel balls. I guess plain steel nuts are no big deal since they can be "greased" without endangering a fifty dollar pair of slacks.
