I am getting ready to start the inverter project and the breaker box in the FW has Murray MH-T breakers what is compatible to put in there? Need a 30 amp single pole.
its against code and dangerous to back feed the main panel from the inverter
use dedicated NEW circuits for inverter output Or use a sub panel for the inverter output, move circuits to the sub panel Or use a transfer switch between inverter and existing breaker output to feed existing circuit
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
