I am getting ready to start the inverter project and the breaker box in the FW has Murray MH-T breakers what is compatible to put in there? Need a 30 amp single pole.
Murray breakers would clearly be compatible; so are at least some Siemens breakers, I believe, and perhaps some others share the same mounting. (Siemens owns Murray). Specifically, you should look for an MP-T series single pole breaker or equivalent. This should not be too hard to find, and certainly not hard to order online. (MH-T breakers are the tandem version of MP-T breakers.)
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
