Colo_NativeExplorerNov 02, 2016RV Breaker panelI am getting ready to start the inverter project and the breaker box in the FW has Murray MH-T breakers what is compatible to put in there? Need a 30 amp single pole.
kellertx5erExplorerNov 04, 2016" its against code and dangerous to back feed the main panel from the inverter"NEC Article 690 specifically ALLOWS an inverter to backfeed into the service panel (690.10(C))." use dedicated NEW circuits for inverter output"That's exactly what the OP is proposing to do.If equipment is properly labeled to indicate multiple power sources, this arrangement is acceptable.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
Related ContentRV Queen entire removal: Circuit Breaker Panel relocateFuse panel locateTripping solar panel breakerBreaker Panel Help PleaseBreaker panel label
