RWWIEFER's avatar
RWWIEFER
RV Fridge wiring
Good morning all I picked u 1996 Skamper truck pop up. Getting everything ready to do a test run for a fishing trip.
Attached are some photos I took of a 2-wire plug that is next to the trailer wire plug for the exterior lights. Traced this 2 wire to a switch to the back of the fridge. It appears this 2 wire goes to a 12 volt externally battery to run a 12v fan that is mounted to the back of the fridge by the coil. Not sure why-except to help with heat. Looks like it was added. The fan is froze up, do I replace it and why does the 2 upper wires one going to a small resistor?. Does that trigger the fan on temp.
Can not see where to add photos.
  • I give up on trying to post pictures. Not sure why there is just not a attachment button but I'm old school so I will move on. I do want to thank everyone for there comments and also the admin for trying to help with posting pic's. I ordered a new fan and switch. Take care all.
  • Doesn't a new user have to have a minimum number of posts before they can post pictures?
    OP, if you can't get the picture posting to work you might try creating a link by using the link icon instead. Of course to do this you need to have the pictures hosted somewhere.
  • Drag one picture into space
    In the box below will be a link for the picture
    Copy that link, paste it in your post
    For second picture
    Repeat process
  • http://photoposting.is-great.net
  • I always thought I was pretty sharp with technology but I still can not figure out how to upload photos. I opened I opened the photoposting link, dragged my 2 photos in there but have no idea were they went. Sorry, this is simple I'm sure.
  • Draft (airflow) across backside of fridge is CRTICAL to cooling process
    Previous owner added fan/battery to enhance the airflow to help with cooling process.
    Sounds like he used a t-stat on the condenser fin ----when fin temp reaches 135* it would turn fan on.then back off when fin temp dropped below 115*F
    (typical temp range----other ranges available so only guess what that t-stat range is)
    Enhanced draft is a GOOD thing for absorption fridges.....FIX/REPLACE Fan/t-stat etc
  • It's probably going to a thermal switch, not a resisitor.
    When it gets hot outside that fan will be helpful.
    I would fix it.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
