time2roll
Nov 05, 2015Nomad
ken burke wrote:That hose (heat tape)really needs continuous electric power to be effective. Probably too much for an inverter run off the battery. Generator would need to run near continuous when temps are well below freezing.smkettner wrote:
Best (IMO) is to have extra battery and 250+ watts of solar.
A couple extra propane bottles may help.
"electric power to the water line" What does that mean? Heat tape?
I will be running a 75 foot electrical heated water hose. (a 50 foot connected to a 25 foot water hose).
Consider instead to fill your existing on-board fresh water tank and the 12v pump will supply you with water. Connect hose only to refill and then remove for the day.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
