j-d
Nov 06, 2015Explorer II
A friend wintered over in Gainesville Virginia. I mention the location because you might be able to figure if that climate is equivalent to where you'll be in VA. "Heated Hose" tipped me off...
In addition to Yes, the Generator will indirectly support your RV furnace, via converter and batteries as discussed here...
...My friend had a local propane gas supplier deliver a 100-pound (or so, it was the stand-up kind, not the bigger "pig") and connect it to the RV. RV was a 36-ft Jayco Fiver, so it had the twin 30-gallon portables like OB mentioned. With the heated hose supplying water, shore tie power most if not all the time, and a better supply of LPG, he and his wife had a comfortable accommodation.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
