Boon_Docker
Jun 30, 2021Explorer III
Grit dog wrote:
Its not leaking on the intake side, it's leaking on the air filter side, which likely isn't "water tight" anyways. The problem isn't the leaking there. But it's likely what wobachop said. Float is sticking. Also means it's inhaling that gas and likely flooded.
Did you remove the sparkplug to check?
And yes if enough gas made it through, some likely washed down into the crankcase. Id' check/change the oil once you get er running.
See if it's flooded first.
I stand corrected.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
