AllegroD
Jan 02, 2016Nomad
Basic principle of an AC with heat pump. Heat pump does not work if outside temp is below about 40° and your furnace should default to emergency (gas) heat if ambient temp is 5° below set temp. If temp is below about 40°, I would turn off the heat pump. It will continually try to run. Not good or necessary.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
