gatorcq
Jan 03, 2016Explorer
Yes, possible it is bad. Normally it is just the switch in the wrong position. Remove the cover and you may notice 2 slide switches in parallel. They are move by the plastic switch cover. Try moving both and ensuring that you hit the correct position. Try removing the fuse also.
My unit is a basement / Propane furnace.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
