dougrainer
Jan 03, 2016Nomad
There is a small fuse on the tstat when you remove the cover. Make sure it is good. Does the Roof AC fan come on when you put in Fan only mode? That will help pinpoint a tstat problem. It is RARE for a tstat to be bad. It is usually a 12 volt supply problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
