MEXICOWANDERER
Jun 17, 2018Explorer
The more ASI credentials you have the more compelling presentation you will have with the public.
A well laid out picto graphic inspection report would make your results more comprehensible to the public.
You need to state clearly in print the thoroughness of your inspection and what it is you are looking for.
You also need to state clearly stuff that is impossible to predict ie transmission remaining life, or, if your inspection does not include chassis running gear. Specifications for heating, refrigeration. water heating. What ate the definitions of Good / Bad ?
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
