LSUTiger's avatar
LSUTiger
RV light bulb
I have a 1986 Winn Chieftain and I need to replace a couple of my interior walkway lights. The bulb is a RHT 250 TWN and I'm looking for an LED replacement. It's a very small bulb, single element. Can't seem to find it anywhere. Can anyone help?
  • if it resembles the picture on the right up above but is much tinyer
    that is a #74
    you can find them at the auto parts store like autozone
    all my dang console rocker switches use them as lamps to indicate the switch is on,
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Batteries plus or super bright LED's would be my recommendations
    Also whever you choose, buy ONE the first time and then in bulk if you like them
    IF those are what I think they are (Common dash indicator lamps) yes, they are small.
  • RoyB's avatar
    RoyB
    Explorer III
    I didn't have any luck as well searching google for the numbers you listed.
    Most 12VDC BULBS used in the Rv Trailers is the 1141 or 921...
    Does your bulb look like either one of these...
    Check the glass bulb an see if you can find a number stamped on that.
    Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
