Old-Biscuit
Apr 10, 2017Explorer III
Nicholsfamily05 wrote:
We have a 50 amp set up at our house and we purchased the receptical that allows us to close the cover all the way. It's nice keeps it out of the elements but makes a great place for. It's to make a nest. That part sucks!
But one leg should be 120volt and the other 110volts with the neutral and a ground with a 50 amp breaker. Pretty cheap to do if you can yourself, if not make sure you get an electrician that knows what they are doing.
I'm not following the 120V and 110V concept :H
As for the electrician part.......50A is normal for an electrician its the 30A RV circuit that they mess up....wire it 240V Dryer/Welder vs 120V
