wa8yxm
Apr 11, 2017Explorer III
Should be 240 volt divided You want the NEUTRAL to be the same gauge as the HOT wires The wiring inside the box will take care of the 120/240 volt division feeding one 120 volt leg to the TT-30 and the other to the GFCI 15/20 and both of them to the 50 as designed.
DO NOT Swap wires or bad things can happen
