MFL
Apr 11, 2017Nomad II
dougrainer wrote:
Regardless of what it states, you will NOT be able to close the door when the 50 amp male plug is plugged in. Does that concern you? If INSIDE then no big deal. But if exposed to the elements, I would NOT want to leave the door open. Doug
Doug...not saying you are wrong, but I have the same CE box, only RV30, not 50, and it is designed for outdoor use. My 30A cord easily fits in the slotted area in lower box, with door closed, and slid upwards for waterproof seal. I think the box pictured, has more depth than it appears. I do realize the 50A cord is larger than my 30A.
Jerry
