joe0508
May 06, 2014Explorer
rv parts
I have a 93 p30 motorhome chassis.Does anyone know where to look for parts for this chassis.
enblethen wrote:Its a four headlight system so each bulb only has two prongs.In other words low and high beam has there own individual bulbs.
One terminal will be ground
One terminal will have power on low beam
One terminal will have power on high beam
You will need to verify by testing lamp. I beleive the single top pin is ground. The two pins are the power. Drawing is on some of the socket packages.
I would still get one like you showed from Summit. That way you only need to do testing once.
