DrewE
Sep 12, 2016Explorer III
I can't think of any inherent reason why a min-split unit wouldn't work very nicely for an RV if installed reasonably. Locating the outside unit might be a bit of a hassle; they tend to be rather tall to stick on the roof, and rather bulky (once you get room for airflow) to easily mount on the back or something. But, I'm sure it could be done with a bit of ingenuity, and would be a good bit more efficient than a typical RV rooftop air conditioner (maybe even twice as efficient, if I understand the numbers properly).
You are aware, I assume, that the "inverter" in an inverter mini-split is not exactly the same thing as a 12V to 120V inverter, and won't run directly off of 12V power (at least in the common cases). It's a variable frequency/variable voltage motor drive circuit for an induction motor, most likely a three phase motor. You'd still need an inverter to power your inverter air conditioner, just like you do to power an inverter microwave oven.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
