BFL13
May 23, 2021Explorer II
AFAIK that solar was for the engine battery. If it is likely to go flat while you are parked on shore power, you can put the engine batt in parallel with the house batts. (Several ways to do that) A common MH problem.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
